Crash with Solo Play on Timelines [fixed]
caboose1408
Post by caboose1408 »
I have a page with only timelines. Whenever I use midi buttons, it works fine. Until I move my mouse cursor. Then the whole program freezes soon after. I am using touchosc.
Re: Crash with Solo Play on Timelines
Does it also crash when you move the mouse, without any connected midi device ?
Please try also with the latest fix (V7.1.29): http://download.thelightingcontroller.c ... roller.zip
caboose1408
Yes I have the latest version. I just tested it with no midi. Works fine. But yeah, whenever midi is connected it crashes. I thought it was midi output affecting it, but it also crashes when I disable output from the button and test it again.
We are not able to reproduce that.
In order to know if this happen exclusively with your midi device, can you please check with another midi device, with and without midi output ?
caboose1408
Just checked with "Live Mobile" for iPad. Works great. But that doesn't solve my issue.
Hopefully we can find out why this is happening.
EDIT: I have also conducted other tests involving multiple different values within the TouchOSC Editor. Checking Input and Output. Crash still seems to happen whenever I'm pressing buttons and moving the mouse. Seems to me that it's an Input value. As if the button input and mouse input are conflicting with one another.
EDIT 2: I have just conducted an input test. I disabled midi input on each button, then I opened "TouchOSC" on my iPad and also opened "Live_Mobile" on my Android phone. I was pressing buttons on the Android and moving the mouse, while the Output shows on the iPad. NO CRASH. MIDI Input seems to be the culprit.
EDIT 3: I also ran a test with Solo Play Disabled. CRASH. Another test with my "M-Audio Keystation 32 MIDI Keyboard" with and without MIDI Output. CRASH
Here is attached information about my setup and crash log.
TouchOSC Editor Settings:
Button Type: Toggle Button
Left Image: MIDI Output | Right Image: MIDI Input
Problem Event Name: AppHangB1
Application Name: TheLightingController.exe
Application Version: 0.0.0.0
Application Timestamp: 5493f803
Hang Signature: 8cde
Hang Type: 517
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Hang Signature 1: 8cde401ce34440b8f3786cd5c8b371ce
Additional Hang Signature 2: 7fc5
Additional Hang Signature 3: 7fc5c7e1309704885f1f7a01c9e7a41d
Additional Hang Signature 4: 8cde
Additional Hang Signature 5: 8cde401ce34440b8f3786cd5c8b371ce
Additional Hang Signature 6: 7fc5
Additional Hang Signature 7: 7fc5c7e1309704885f1f7a01c9e7a41d
Please post (or email) your lightshow.
We will check that.
caboose1408
How is the research on my lightshow going? It's been about 3 weeks and I'm still unable to use my strobes with the iPad. I'm just really curious.
caboose1408
Here's an update of the main problem. On the strobes page, the AllStrobes timeline button is the culprit which crashes the program.
Fixed for next release
