How to show "old" parcans with different colors [fixed]
Lighter007
Post by Lighter007 »
Hello everyone.
I´ve got a question about editing fixtures.
Example:
I create a fixure, for example a Par can and patch it 8 times beacause I have eight of them in real. I set the beam color to white for all of them.
Now I put a green color filter on numer 4. (in real-life). I also want to have number 4 yellow in 3D-View. So I open number 4 in the fixtures editor, change the beam color to green and save. The problem is:
If you edit one fixture of a group of fixtures which you created together, the changes will be saved for all fixtures of this "virtual group".
So how can I only change just one fixture without recreating it completely new?
This also happens with dmx channels, levels, etc, not just the beam color for 3D-View!
Greetings
Lighter007
Greetings from Germany! :)
zkflow
Re: Independent editing of a fixture
Post by zkflow »
Well, for me its about the logic of the software. In other words, you are using a fixture with a unique configuration. It means, you can put 99 Par Cans, and all would be the same, because they read the same configuration file. A solution could be "create" a new fixture with diferent configuration, or a new function called "Make independent" or "Make Unique"....
And for make independent the 4th fixture from the rest... you must use "duplicate" instead of "clone"
Please send your lightshow.
We will check that.
Lighter007
Here it is.
You will see:
The first four fixtures I created "together", if I change anything on one of these it will be saved for the other three, too.
The other 2 fixtures I created seperatly and you can change anything which will not be saved.
So: Will be there an option (check box or something) to enable changes to just be saved on the one fixtures which is selected?
You effectively have to create one "parcan" fixture, for each different color.
Like in the attached lightshow.
