Can not set the column "fix" for the channels [fixed]
MTF Showtechnic
Post by MTF Showtechnic »
Some translation faults to German language – ok I’ve fixed them in the corresponding file.
But one fault is still left: In the Editor the Button “Add new Fixture” remains with the text “Add new fixture” although the german text in the file is right.
I’ve created a 12Channel dimmer. In the features of the fixture is a column called “fix”. I guess this should be the “Force Editor” like it was in 6.34.
If it is - it don’t work.
greatings
Re: Here are some Faults / Bugs? (7.1.23):
Thank you for this report.
We will check that as soon as possible.
If possible, please post (or email) the fixed German language file.
MTF Showtechnic
ok here it is.
But what about the column "fix" in the features of a device? Especially by my 12Channel dimmer?
Roland
Fixed here: http://download.thelightingcontroller.c ... roller.zip
(sorry for the delay ; this is due to some other bugs to fix simultaneously)
MTF Showtechnic
Re: Can not set the column "fix" for the channels [fixed]
No problem - again nice work! ;)
I've exchanged the exe and the dll but haven't found the "efk_hardware.dylib" file in the software. What about this??
And by the way - in the Edit Fixture Menu the "Fix" column is called "Popup_FEChannelStrictValues"
The german translation doesn't work because the phrase isn't listed in the german.ini.
I've completed this and now it works.
Please look to the attached screenshots 'cause there are some buttons still in english:
Top = Add Fixture Menu
At lower left = Complete software preferences
At lower right = Timeline preferences
All translations are correct - but you see the results.
greetings from germany
Roland
[deleted]
The attached INI file will come with the next complete software version. Please try it.
Please note that the new functions are supplied with English translation only (it would take too much time to get the translation for each country). We will update to correct language may be once a year (9 languages to update each time).
The fix ZIP file is available for both Windows and MacOS. The file "efk_hardware.dylib" is for MacOS only. You can leave it ; it will not affect your Windows software.
MTF Showtechnic
Again I can say only one thing - Great Software - greater support.
I know that it would take too long to translate all languages.
Therefore I take a look for myself but can't find a translation problem in the Ini.
Anyway...
I wish you a merry Christmas and a happy new year
greetings
Thank you.
And Merry Christmas too !
Return to “Editor - Fixtures”
