Midi to Master Fader crashes (v7.1.21) [fixed]
caboose1408
Post by caboose1408 »
I have applied a Master Fader with TouchOSC MIDI controls. Whenever I opened 3D view and used a fader, the entire program stopped responding.
Re: Master Fader crashes with 3D view. (v7.1.21)
If we right understand:
- the Master Fader with TouchOSC MIDI works well, until 3DView is off
- if you open 3DView, as soon as you move the midi fader, the main software window crashes
Can you please confirm this ?
If yes, can you please make a test with a basic midi button triggering a button in Live, instead of using a midi fader ?
(if no crash, this could mean that the problem is "too many midi messages")
caboose1408
It only crashes when fader moves while in 3D View.
I have also replicated the error with a midi button controlling a master fader. Where it goes from "-100" to "+100". After pressing about 10 times within 5 seconds, the program crashes once again.
Here is a screenshot with an included Windows error report of the midi fader.
http://i62.tinypic.com/23kp0zn.png
Problem Event Name: AppHangB1
Application Name: TheLightingController.exe
Application Version: 0.0.0.0
Application Timestamp: 5476dc18
Hang Signature: 8cde
Hang Type: 517
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Hang Signature 1: 8cde401ce34440b8f3786cd5c8b371ce
Additional Hang Signature 2: 6971
Additional Hang Signature 3: 69719bade259e2efa3080d8134d39384
Additional Hang Signature 4: 8cde
Additional Hang Signature 5: 8cde401ce34440b8f3786cd5c8b371ce
Additional Hang Signature 6: 6971
Additional Hang Signature 7: 69719bade259e2efa3080d8134d39384
Thank you for the clear explaination.
We are now able to reproduce this problem.
We will fix if asap.
Fixed for next release.
zkflow
Post by zkflow »
thanks!! actually i had the same problem sometimes... using the NANOKONTROL... my way to solve this was patch to DMX channels directly...
caboose1408
You guys are quick!!! It now works very well. I'm glad to have said something about this bug. I do lighting for a job, so as you can see I heavily rely on this software.
Thank you !
We will do our best to support you.
Return to “Buttons”
