[fixed] The manual does not open from the menu
zkflow
Post by zkflow »
when i want to see the manual, automaticatly the software sends me to GOOGLE... not to the manual... this its to bad working offline :(
https://www.google.com.mx/search?q=C%3A ... 8wfC5oGwDA
Re: A little error
The software asks the system to open the PDF file, which is stored in the software folder.
If, in your system, the PDF extension is associated with a PDF file reader (like Acrobat Reader, Foxit, ...), you should see it.
zkflow
Re: A little error
Post by zkflow »
yes, i have the Acrobat... its not a very important bug but for new users... probably they get lost.
Re: A little error
When you double-click on the PDF file, does it open with Acrobat ?
Re: The manual does not open from the menu
You can forget our previous post.
We found that our code sometimes does not work under some versions of Windows.
Fixed for next version.
