I have a color problem with my par cans.
In the setup, I create a par can. In the middle section, I choose the right light bulb, the the beam angle, then there is a beam color button.
In the channels section I add "Dimmer".
So now, in 3D mode, I see the par which lights according to my fader in the editor. But it is white...
The "beam color" button doesn't seem to affect the par color. I tried to change the Dimmer channel into a color channel, but then there is no dimming, the par stays on...
How can I use the Dimmer channel AND have the right color in the 3D view?
Thanks...
Par_Can color stays always white ! [fixed]
Re: Par Can - Color?
This is a bug. It is fixed in the beta version : http://download.thelightingcontroller.c ... ware/beta/
You have to:
1 - install the beta software
2 - add the fixed files (fix_for_Windows.zip)
You have to:
