Same fixtures at same dmx address, with different behaviour
post here other topics
CQE DJs
Post by CQE DJs »
So I have some Blizzard pucks I use to light up my trusses and American DJ Mega Go Bars to light up my front board.
All my pucks have the same address so those should be working together and all my ADJ bars have the same address so those should work together.
I made a scene where they slowly fade colors, but I noticed that 1 out of my 4 pucks is a little slower when changing thus being off and same with my ADJ Bars...1 out of the 3 is a little slow when changing.
Anyone experience this? Any way around it? They are all the same address so they shouldn't be doing anything differently. Thoughts?
Re: LED Lighting Fade
So far, the couple dmx interface & PC software can not be the cause of this problem.
Lighter007
Re: Same fixtures at same dmx address, with different behavi
Post by Lighter007 »
In some fixtures you can select between different Dmx-Channel modes. Maybe you set the first on 6 Channel mode and the other ones on 7 Channel mode for example. Maybe thats the problem?
Greetings from Germany! :)
CQE DJs
Post by CQE DJs »
Checked that already, they are all on the same.
Going to do some major testing out either next weekend or the following. Don't have time to do it any sooner. I'll update with my results but wanted to throw it out there first if someone had the same issue and knew of the cause/solution off the bat.
JohnRichards
Post by JohnRichards »
My suggestion is to go back to the basics, and plug one unit in at a time (on its own) and see if there are any changes.
Check all cables and terminators.
John
zkflow
Post by zkflow »
check if you have a DMX terminator. Or the cables have problems (another pin-out, or bad construction)
CQE DJs
Post by CQE DJs »
going to do all of that when I test plus a few additional things (factory reset fixtures) etc...
I did experience 1 bad DMX cable already that threw half my setup into a complete frenzy. got rid of that but haven't done thorough tests on everything yet.
zkflow
Post by zkflow »
typical problem... one little cable (or sometimes bad pin connection in conectors) ruins everything
Return to “Other”
