Howto controle Sweetlight by Midi trigger iPad
dfgnodde
Post by dfgnodde »
Hi All,
I did want to controle Sweetlight Controller by an MIDI Pad. my first plan was to buy af novation launchpad but then i thought is already have an iPad with a midi controller.
So i purchased the S1MidiTrigger APP and played with it. all works fin and you even can make your own sliders buttons etc. etc.
Then i thougd it should be posible to use midi over WIFI. after some puzzeling in several forums i came up with the following setup.
For use with Sweetlight you need to have an internal midi server. i found one called LoopBE1 downloadable for free at.http://www.nerds.de/en/download.html
install it and it looks like this
now you need the DSWifiMIDI server. downloadable at https://code.google.com/p/dsmi/download ... .zip&can=2&
Select LoopBe Internal MIDI as input and output.
prefs sweetlight.png (31.43 KiB) Viewed 12506 times
Now you have to set the prefs in the iPad got to the settings and choose DSMIDI as your server in connection Settings
Now you are ready to go.
(MIDI out does not work 100% stil in developmend)
Good Luck
dfgnodde
Re: Howto controle Sweetlight by Midi trigger iPad
Post by dfgnodde »
Settings screen in S1MidiTrigger APP
S1MidiTrigger APP
zkflow
Post by zkflow »
nice setup!!
i'm doing some experiments with a similar setup... BUT using the next software:
TouchOSC (Android)
and for the MIDI ports i'm using software by Tobias Erichsen
http://www.tobias-erichsen.de/software.html
ULTRA-Recommended for virtual MIDI Stuff
