Driver problem
priza166
Driver problem
Post by priza166 »
Hello i downloaded the drivers from the link in FAQ's "all the drivers you need" i did the process to install them and then my pc says "we found the driver but for some reason the installation failed" code10. Please help me as soon as possible
Re: Driver problem
In order to know if this problem is only with your pc, could you please try with another pc and let us know the result ?
priza166
Re: Driver problem
Post by priza166 »
Ok i'll try it on another pc and i will inform you
tomdavi
Re: Driver problem
Post by tomdavi »
Hi I have the same problem - on checking the drivers and cable it appears I have a v1.06 cable and the driver calls itself 1.05.
The cable works fine on my desktop which runs windows 8
Its very annoying ! Help much appreciated
T
Return to “Cable”
