generated scene is a blank file
zkflow
Post by zkflow »
yesterday i was working in a new pixels array... and for example... i do a chaser... i tested it using the DMX button... then i save it.... load to LIVE... and IT DOESNT CONTAIN ANY INFO.... ITS A BLANK FILE....
IDK if this only happens to me...
Re: pixels its working right? (last version 7.1.14)
We just double checked ; it works ok here.
May be we need a complex lightshow to see the problem ?
Are you able to reproduce the problem with a very small lightshow ?
PS: the scenes generated by Pixels are located in folder "../scenes/pixels/"
pogjack
Re: generated scene is a blank file
Post by pogjack »
I'm actually having problems on two machines with pixels not properly showing out. Also them not plan on live.
Another machine I have seems to be working fine though.
zkflow
Post by zkflow »
support wrote:We just double checked ; it works ok here.
yes, they were generated, but i try to run it on LIVE ... AND ITS A BLANK FILE!!!!!
i'll try with an another show... it was a headache this saturday programming a show... finally i used the generator and workd great... :|
You can post (or email) your lightshow (with Pixels blank generated scenes) ; we will check them.
zkflow
Post by zkflow »
actually i deleted it :|
but the next week im going to use the same PC (provided by the production company where i work) and the same software version...
Return to “Pixels”
