WaveForm is not visible when file is stored in ... [fixed]
JohnRichards
Post by JohnRichards »
Hi Support,
Very disappointed to find that this is now not part of the software anymore (Ver 7.15)
John
Lighter007
Re: WaveForm
Post by Lighter007 »
:o :shock: :cry:
Greetings from Germany! :)
Re: WaveForm
Can you please tell us more ?
JohnRichards
Re: WaveForm
To Support -
I only use wave files for shows, and I cannot see them on any of my shows.
Will do a couple of more test to confirm.
John
Re: WaveForm
We found the following problem in V7.1.5: if the wav file is stored in the lightshow folder, the waveform is not displayed (this is fixed for next version).
But, outside of this problem, we always see the waveform.
If your wav file is not in the lightshow folder, and you do not see the waveform, please send us the file (if too big, please use http://www.wesend.com or similar).
JohnRichards
Re: WaveForm
Hi Support,
Yes you are correct. If the file is anywhere else other than the current lightshow folder, it does display.
Thanks for making the change for current folder, as I try to have all files for the show in a dedicated music folder.
John
Re: WaveForm is not visible when file is stored in ... [fixe
JohnRichards
John
Return to “Live - TimeLine”
