Snapping to Audio Points
Lighter007
Post by Lighter007 »
Can you add a function to remove the "Light-scene-snapping" to the audio points when a Track is existing?
It may be a good idea but for fast light scene changing it´s defenetly to unprecise.
Lighter007
Greetings from Germany! :)
Re: Snapping to Audio Points
Can you please explain the "Light-scene-snapping" ?
Lighter007
OK after some testing I came to this:
This problem has nothing to do with audio snapping, it was a false interpretation of my.
The problem occurs when I want to lay multiple scenes about each other because then I cannot place them as precise as when I set them alone in a Timeline.
EDIT: It does not always happen! :? so you may not able to reproduce it.
Now everything works fine. :|
Return to “Live - TimeLine”
