Screencontrol ?
copy/paste section is available in TimeLine
jaxx00974
Screencontrol ?
Post by jaxx00974 »
I am getting into V6 now and impressed.
One problem though, I use the video timeline to display JPG's in the screencontrol window and they now behave weird in screencontrol ?
Before in V5 I would place a a few JPGs in the timline and they would display as and when the marker reached them without fail.
Now in V6 it shows the jpg for a split second then instantly pastes the next JPG ontop of the first which creates an unholy mess ?
Can it become like it was in V5 ie the jpg shows in my screencontrol window as and when I place a jpg there ?
Regards,
Lee.
jaxx00974
Re: Screencontrol ?
Post by jaxx00974 »
Just an update.
I have logged into my windows XP 32 buit) and screencontrol works perfect. I was using Windows 7 64 bit when the screencontrol showed faulty so this seems to be to do with either 64bit Os's or Windows 7.
Thanks a ton guys,
Lee.
jaxx00974
Re: Screencontrol ?
Post by jaxx00974 »
Ok it was my fault. Screencontrol works great.
For the record, my JPG's where res 1280*1024 and my second output monitor was res 1024*768 causing a mis-shaped display, feel a bit daft but there you go !
Solved (but not really broken lol)
Jaxx.
Re: Screencontrol ?
Anyway, this problem is abnormal (we are able to reproduce it) ; so we would like to fix it, before releasing a stable version.
We uploaded a fix with a new "ScreenControl.exe" file (in same folder than beta software).
Could you please try this fix (replace the exe file in folder "ScreenControl"), and let us know if no more problem, with any screen resolution ?
jaxx00974
Re: Screencontrol ?
Post by jaxx00974 »
Ok - tested on all native resolutions, all testing ok, works great.
Thanks gents,
Lee.
Re: Screencontrol ?
Thank you for your answer.
Now we know what is exactely the problem in beta version of ScreenControl.
jaxx00974
Re: Screencontrol ?
Post by jaxx00974 »
Your welcome, I appreciate the speedy response and fix.
I am just hopeing you have read my post late last night regarding the scenes. With the scene problems fixed I can use V6.24 to work extremely fast with pleasure. It is such a huge positive leap forward in software.
Fingers crossed,
Lee.
Return to “6.24 beta”
