buttons do not switch between each other when press. [fixed]
rando
Post by rando »
Hi, we have two panels of buttons, one for house lights and one for stage lights. When we click between the House Lights buttons, switching between different levels of light, the previously selected button will always turn off so only one button is activated at one time.
However, with the stage lights buttons, they remain selected regardless of if we click other buttons or not. The only way to get them to not be "highlighted" is to click them to turn them off then click another button.
While it's not a complete dealbreaker, it does pose a confusing situation for users who aren't experienced with the software as they can no longer tell which stage lights are actually on and which were just left "on" by the software. Can anyone help pinpoint where we can mark the button to turn off if another button turns on?
Attached is a screenshot of our button panel.
Notice the house lights panel only has one button selected while the stage lights panel has three buttons for the same controller selected. Thanks!
Re: buttons do not switch between each other when pressed
Post by Pink LD »
Is the Stage Lights window set to Solo Buttons?
Lighter007
Post by Lighter007 »
It is. You can see that on the little symbol left to the page header "House Lights".
It's easy to remove: Right-click on the Dropdown-menu/page header called "House Lights". Enable or disable the "Solo buttons".
Hope this helps you!
Lighter007
Greetings from Germany! :)
The page "Stage Lights" does not show the "solo button" icon, which means the option is not set.
rando
Re: buttons do not switch between each other when press. [fixed]
Post by rando »
Thanks everyone! Really appreciate it. I'll try it this weekend and post then on my results.
Return to “Buttons”
