Request: Resizeable DMX-MIDI Patch window
eedetail
Post by eedetail »
Title says it all, If you are making time to be able to resize the DMX Levels window, I would like to be able to stretch the DMX-MIDI patch window.
Its not a big deal, but I do a fair amount of dmx patching from my wing console thru Showexpress, using the first 24 channels. Any channel after 10 i always have to run the slider down.
As I said, you have much bigger items to work on, but if there is enough interest throw this one in the que please.
TimE
Re: Request: Resizeable DMX-MIDI Patch window
Yes, this is not urgent, but it is noted.
Post by Pink LD »
I agree. When I am softpatching festival rigs of typically 120K, I am patching a lot of numbers. My view is often obscured because the sting of numbers I am patching is longer then the edit window will show, or in in fact what the window will show.
So one of us wants to see more lines, and the other wishes to see longer lines.
Noted.
