Stage moving
DjNatLive
Stage moving
Post by DjNatLive »
H all
i am building a stage on the 3d view for a show im doing.
everytime i put in a new stage it moves everything out of line ???
also
i open the object setting and try to click on the object but it wont let me select it, i have to go through the list to choose it and then use the slides which is taking ages to build a huge set i have.
Can someone please explain to me how to change this
Re: Stage moving
The size of the stage must be set before positionning the fixtures.
If you change afterwards the size of the stage, you have to position again the fixtures.
DjNatLive
Re: Stage moving
Post by DjNatLive »
Hi
I know this. but its when i add a new object the whole thing moves out of line.....
i dont change the size of anything everytime i put a object in to the workspace all the objects move not the fixtures its a dry stage at the moment have no fixtures in
Re: Stage moving
Please post (or email) a ZIP of your lightshow, and tell us precisely what actions to do to reproduce the problem.
We will check this.
DjNatLive
Re: Stage moving
Post by DjNatLive »
support wrote:Please post (or email) a ZIP of your lightshow, and tell us precisely what actions to do to reproduce the problem.
We will check this.
What is your Email address soo i can send the file.
Re: Stage moving
DjNatLive
Re: Stage moving
Post by DjNatLive »
i have sent a email to yourselfs
Re: Stage moving
You sent us only the file "3DView.ini".
We need the complete lightshow.
viewtopic.php?f=3&t=168
