6.21 [fixed]
directsound
6.21 [fixed]
Post by directsound »
I used 6.21 for the first time tonight For some reason my lights would just start flashing speratlicly for exsample I had all pars red they would change but just some of the and they would all change kind of like they were in sound active mode ...I restarted my PC with no luck also at first I was useing the Remote then tryied the XBox same issue with both boxes but when I woulc unplug the DMX cord from the box the Lights would settle down right before the built in show would take over ... I Have a big lighting presentation today and I hope I dont have spactic lights Im going to try to go back to 6.20 if I can to settle it back down ...any Ideas??????
Thanks DJ Mikey Mike
Thanks,
From DJ Mikey Mike
http://www.directsound.com
directsound
Re: 6.21
I went Back to 6.20 and the issue went away did yo find a probblem?
thanks
DJ Mikey Mike
Thanks,
From DJ Mikey Mike
Re: 6.21
We did not find yet any problem regarding dmx. Could you please tell us:
- the OS (XP, Seven, ...)
- the processor (or just how old is the pc)
- 32 or 64bits
- which interface
directsound
Re: 6.21
Its a HP dv9700 32 bit Intel Dou T9300 @2.50 GHz x2 running vista
Thanks,
From DJ Mikey Mike
Re: 6.21
And with which interface you have this problem ?
Could you also tell us if this problem exists with all interfaces ?
directsound
Re: 6.21
I was useing the remote and changed to the Xbox using sweetlight for both
MM
Thanks,
From DJ Mikey Mike
Return to “Windows”
