6.333 - Editor Crashes when using Paste All Steps !!URGENT!!
create lighting scenes
johntankard
Post by johntankard »
Hi Guys,
Require a little urgent help here. I have created a very simple chase in the Pixel mapper for some LED par cans, it was created under the previous version. I now have a big corporate do on Wednesday and am trying to do the same thing except when I generate the effect as a scene and then in the editor open the shutter and up the dimmer and then apply to all steps the editor crashes. I have tried this on multiple pcs and it will not work, can I get a copy of the previous version as it worked fine in that and I doubt you will be able to get this fixed by Tuesday night.....
Regards John
Re: 6.333 - Editor Crashes when using Paste All Steps !!URGENT!!
Post by Pink LD »
The first topic in the FAQ's section of this forum is all the files you need. But if you scroll down to the bottom they provide links to Ver 5, it's no longer supported but that may help you at this point. Also included is a convertor programming to upgrade from Ver 5 to Ver 6. Best of luck, I hope this helps.
Please post your lightshow, and tell us exactly how to reproduce the bug.
swindass
Post by swindass »
swindass wrote:Please post your lightshow, and tell us exactly how to reproduce the bug.
How do we do this?
Thanks ;)[/quote]
Ok just sent lightshow.
Return to “Editor”
