New Live Beta - problem with preset [fixed]
JohnRichards
Hi Support.
Loaded new Live.exe in my Beta folder, and have run a few tests.
Only problem found is on a PreSet Button.
If I press the button and move the slider, and then close the button, the scene carries on running.
If I remove the PreSet slider, the scene is ok. If PreSet added again, and button activated and then de-activated, no problem.
Please check.
Please check.
Re: New Live Beta
Please post the smallest possible lightshow showing this problem.
JohnRichards
Re: New Live Beta - problem with preset
Attached find small show with problem.
To see what I mean, activate "preset button" and change the position of the slider.
After the scene fades out, it continues to restart.
After more testing, it only occurs if "fade in" or "fade out" is set to the button.
John
John
- BetaLiveTest.zip
- Sample of problem
- (10.75 KiB) Downloaded 652 times
I have had a similar problem but I have not yet gotten round to looking at it exactly to diagnose it. The beta file is working for the the what I asked it to work like but the fade in and out feature does not seem to work right for the dimmers of my moving lights. The same as is described in this post.
ashley.saylor@facebook.com
http://projectpinkband.com/
http://johnnywadband.com
JohnRichards
@Support,
Any feedback on this error as yet?
John
John
Sorry, we forgot to take care of this problem.
Thank you for the clear test lightshow.
We are now able to reproduce the problem.
We come back to you asap.
Fixed in beta Live (http://download.thelightingcontroller.c ... a/Live.zip).
Re: New Live Beta - problem with preset [fixed]
Cool, I'll try it out in a few hours.
JohnRichards
Tested, and problem is solved.
Thanks Support
John
Thanks Support
John
I concur with John Richards. It looks like it's fixed. Thanks!JohnRichards wrote:Tested, and problem is solved.
Thanks Support
John
