deleting fixtures bug
dj106fm
Post by dj106fm »
when i delete a fixture with the same name as another one the setup deletes the one with the lowest dmx address which is annoying because when you need to delete an item (i name my light 1-100 per fixture so say par can would be 1 and a mega bar would be 1 as well because the i know how many of each fixtures i have
Re: deleting fixtures bug
It is normaly not possible to have two different fixtures, with the same name !
dj106fm
Post by dj106fm »
support wrote:It is normaly not possible to have two different fixtures, with the same name !
it says an error but adds it anyway
We are not able to reproduce this problem ; we will try again.
In the meantime, please use different names.
dj106fm
Post by dj106fm »
support wrote:We are not able to reproduce this problem ; we will try again.
i will i am having other problems with the software that i am trying to fix now but it might be that
Return to “Setup”
