fade up/fade down button feature [fixed]
Post by Pink LD »
I have my entire wash of par LEDs patched to four handles on my wing console. I also have macros with key board shortcuts to put a select artist in no colour. I use the fade up/fade down function to transition the primary colour in the wash to a NC on a select artist. When I deselect my keyboard trigger, the NC used to fade and then release, allowing whatever colour mix I had up in the wing console input.
Now the fade up/down works as it's supposed to. However it no longer releases the lights selected by the keyboard shortcut.So those lights no stay blacked out until I ctrl+alt+z and push down my wing console handle and bring it back up. I don't like either turning off the fade down on those buttons, getting a snap NC off, or having to dim wash, ctrl+alt+z'ing and bringing up the wash again. Is this a bug?
Re: fade up/fade down button feature
Can you please post the smallest possible lightshow illustrating this problem ?
By the way, what is the meaning of NC ?
Post by Pink LD »
NC=No Colour, or white if you prefer. Or a full mix of RGB.
I will have the rig up Fri & Sat, I will take a short video of what I do, what it now does, and explain what it used to do. Like before I will post it to YouTube and post a link here for you to see.
If that is not clear I'll create a simple single par example setup for a wing console with a 1:1 patch and a macro so you can play with/replicate what I am experiencing.
Post by Pink LD »
I changed the patch priority to "Highest Level Takes Priority" and it is working the way I I am expecting it to.
Return to “Buttons”
