Master faders on level "dimmer" of channel "shutter" ?
DJ Trenco
Post by DJ Trenco »
I have a question about the master fader. If I right-click on the fader and click on edit, I can select my rgb fixtures. But I have a lot more fixtures including scans and movinheads. These two fixtures use a dmx channel caled "shutter" and from value 2-63 is the dimmer. Is there a possibility to use the fader so i can dim also my scans and movinghead?
Re: Master fader question
The master fader can be linked to following channels: RGBWA and dimmer
It acts inevitably on whole dmx range (0 to 255).
We suggest you to use the option "fader button", which comes with the buttons.
Return to “General”
