Deleted fixtures...how do I put them back?
davelerbakken
Post by davelerbakken »
I added some scanners, but took out some par LED's. The WRONG par LED's in 'Setup'. Is there a way to restore them with the correct DMX addresses?
Thanks,
Dave
Re: Deleted fixtures...how do I put them back?
If we right understood your question is: "how to get back something i have deleted ?"
There is a function "export lightshow", which is made to save your complete lightshow (for instance in a usb stick). Then you just have to use the function "import lightshow" to get it back. If you did not save your lightshow, there is no way to get back the deleted files.
Return to “Setup”
