Master Faders output % display using MIDI... [fixed]
chris226
Post by chris226 »
I love the addition of the MASTER faders! Thank You. One small issue: When I use a MIDI controller to adjust the Master faders, the fader's output "%" display does not change. The fader moves and the actual output is correct , but the % display does not change
For example: If I drag the fader to "-80%" using my mouse; the fader moves, and the display above it says "-80%". However, if I now adjust the knob on my MIDI controller that is assigned to the same fader, the fader (and actual output) will change accordingly, but the displayed "%" will still say "-80%". If I I make a MIDI adjustment then, click the fader with my mouse; the correct "%" will then be displayed, (until I make another MIDI adjustment.)
Chris Ping
Light and Sound Tech.
Art Bar
Lexington, KY
Re: Master Faders output % display using MIDI...
Thank you for this report.
Noted in TODO list.
Fixed in next EXE/APP file.
chris226
Re: Master Faders output % display using MIDI... [fixed]
Post by chris226 »
Thanks!
Chris Ping
Art Bar
Lexington, KY
Return to “Buttons”
