How to merge two generated scenes together? [fixed]
create lighting scenes
Callum Allan
Post by Callum Allan »
I was wondering how to merge two generators in one scene?
I have 2 sets of different moving heads with different channels and when I do one and then it overrides the scene and makes a new one.
Is there anyway I can merge the two generated scenes together?
Thanks,
Callum Allan
ShowXpress V8.2.28
DMX512 Interface
APC Midi Mini Controller
Re: How to merge the two generated scenes together? [fixed]
Build & save two "generated" scenes, and use the function "File > Merge", in main menu of Editor.
g3hcl101
Post by g3hcl101 »
support wrote:Build & save two "generated" scenes, and use the function "File > Merge", in main menu of Editor.
I tried this with two separate scenes I had created, each one only containing a generated path on different mover heads, but when I merged the scenes it still overwrote the path I had made. How is this supposed to work?
Re: How to merge two generated scenes together? [fixed]
Sorry but we do not understand "overwrote the path". Otherwise, please proceed like this:
- open the first scene
- use function "merge" and select the second scene
- use function "save as" to save the new created scene in another scene
Return to “Editor”
