[V6.33] Possible Bug [fixed]
create lighting scenes
FlipC
Post by FlipC »
So I originally posted in 3D View but now feel it is an Editor Issue.
(viewtopic.php?f=13&t=2054&p=8742#p8742) CLOSE this one BTW.
To recap:
"So I just took a break from creating a scene to post some thoughts about a Possible Feature over in the General forum.
Once I posted I closed browser and reloaded Show Express. Opened my scene and started 3D View. Checked the 3D button and hit play. And NO LIGHTs are on. I see them moving but they aren't "ON"
Also 2 of them aren't moving. And Gobos aren't showing.
Channel sliders are where they should be but not doing anything. Even if I change them.
Just DISABLED one channel and it will work after BUT not after I save and reopen.
Today at work I tested on rig and real life and 3D view are same.
So it seems it's an editor issue. So now I just started recreated the exact scene. Step (0.05) one is simple.Change location of moving heads. Step 2 (03:55) fades in 6 out 10 heads. 3D View showing correctly.
Went to play it and noticed I didn't set 2 of those 6 heads starting point in step 1 so I went back to step one and changed there X and Y. Guess what - NO LIGHTs ON again.
FlipC
Re: Possible Bug
Post by FlipC »
Just tried it again.
This time it didn't do it until I saved and reopened ...
I uploaded this scene file (someone deleted my other one from #D View post ... )
FlipC
Re: Possible Bug
Post by FlipC »
Every time.
Just made another test. step 1 1 second and step 2 3 seconds to see if that effected. Works until I save file.... FRAK
FlipC
Re: Possible Bug
Post by FlipC »
OK There is a BUG.
Exactly what it is I cant say. BUT I just tested the scene I created (talked about Prior post) in version 6.31 and 6.32 and it works correctly in BOTH of them. Retested in 6.33 and does not work correctly.
AND now to RANT. It is FRACKING RIDICULOUS NOT TO HAVE PRIOR VERSIONs on this site for us to down load.
It is not about supporting OLDER versions BUT rather US HELPING YOU figure this shit out.
FlipC
Re: Possible Bug
Post by FlipC »
OK
So the testing I just did was this:
I took and used the 6.32 Editor file within 6.33 - still same issue.
I then took used the 6.32 3D View file within 6.33 - still same issue.
That is as far as I am going with the testing because I then took the 6.33 LIVE and am using it within 6.32 and it is all working correctly. Will test on RIG tomorrow.
(Oh yeah THANK YOU for bring back the tab'd Buttons. That free floating page SUCKED. Now just allow us to have as many pages as we want like in Version 5!)
Re: Possible Bug
We are working on this problem ; the fix will arrive asap.
Re: Possible Bug
Return to “Editor”
