[V6.33] no dmx outputs for second universe [fixed]
create lighting scenes
dkumpula
Post by dkumpula »
I just installed version 6.33 and the Editor no longer outputs DMX. I did reboot after the install and it still did not work. Installing the prior version (6.32) returned the Editor to working status.
Will you please take a look at this?
Thank you!
-David
Re: Editor v6.33 No Output to DMX
Please post your lightshow and specify how to proceed, in order to see the problem.
By the way, please tell us if you see the channels moving, in the dmx levels window.
boes1234
Post by boes1234 »
we have the same problem.
universe 2 is not working in the new software.
both universe are xpress 512 plus
dkumpula
Post by dkumpula »
Yes, I just confirmed that is only a problem with Universe 2 here as well. It also isn't limited to just the Editor, as Universe 2 does not work in Live either. In my case, Universe 2 is an older ShowXpress Plus controller. Both versions of ShowXpress indicate they recognize both of my controllers, but 6.33 won't output anything to Universe 2. As soon as I reinstall 6.32, the problem goes away.
-David
Re: [V6.33] no dmx outputs for second universe [fixed]
Fixed.
Please copy files from here http://download.thelightingcontroller.c ... fix_files/ (both Editor and Live) to correct folders.
Return to “Editor”
