Movinghead control by joystick
Ecoflac
Post by Ecoflac »
Dear Lighting Controller Team!
Iv'e testet the DMX Control software and they've got a joystick control option for movingheads. :D
Is it possible to integrate such a option for Sweetlight to control the x and y axis with a joystick?
Ecoflac
Re: Movinghead control by joystick
We have doubts about using joystick to control a moving head (540° for pan and 270° for tilt) !
We need to wait for other users mind.
pogjack
Post by pogjack »
I put my vote in for it.
Ecoflac
Post by Ecoflac »
But this would be a great feature.
You could use a relative deflection e.g. if you tip the joystick to the right, the x coordinate changes one step.
If you push it for some seconds to the right,the movinghead moves till you stop pushing.
Sorry for my bad english,
Ecoflac
Noted.
FlipC
Post by FlipC »
have you ever used a joystick to program moving heads?
I have hardware controllers that do have/use joystick. Since this software has no real time recording capabilities it would be a PITA. Just use a trackball on the POINT pad (name?) within Editor. Same thing.
mpguidry
Post by mpguidry »
It is doable. One day I was bored and plugged a wired Xbox 360 controller up and downloaded a program called midijoy. Midijoy converts windows gamepads to midi messages. Each button is midi mapped and each axis is midi mapped, you can set each button/axis to what ever midi channel/note you want. If you need help setting up and I can make a tutorial with pics
Thank you very much for this info.
