How to control the channel "dimmer" ? [fixed]
dax831
Post by dax831 »
Hi
We are adding some Eurolite Pin Spots to our show and would like to use the Pixels feature with them.
The units have DMX channels Red, Green, Blue, Master Dimmer and Control. When using pixels the units don't illuminate as there doesn't seem to be an option in Pixels to control the dimmer channel.
The manual can be found at
http://media.steinigke.de/documents/00052425.pdf
Is there a workaround for this?
Regards
Paul
Re: Dimmer in Pixels
It is possible to force channel 4 (dimmer) to 255, in Pixels, like this:
In Fixture properties > section "Shared channels", you have to set the dropbox "Last channels" to "2" (means RGB are followed by 2 channels).
Then click on "Edit" to open the windows "Shared channels".
In the window "Shared channels", set the first fader (following RGB colors) (this is "dimmer") to 255.
Click on "close".
PS : you can also fix a value for channel 5.
dax831
Post by dax831 »
Many thanks.
Paul
Return to “Pixels”
