Dimmer Channel not working in 3d [fixed]
Johnny
Post by Johnny »
I have a 12 channel RGBAW fixture (flat par can) where channel one is the dimmer and channel two is the shutter channel. I cannot get the dimmer channel to dim the fixture in 3d mode. It works when I have the fixture setup but would like to program shows with out having to hook up all 30 lights to make sure the show is correct. I have the channel set up as dimmer and then the settings set to dimmer 000-255
Re: Dimmer Channel not working in 3d
Please post the fixture file (in a ZIP file).
We will check it.
Johnny
Post by Johnny »
Please tell me how to do this
Johnny
Post by Johnny »
I hope I did this correctly
Fixture Profile.zip
(408 Bytes) Downloaded 990 times
- the fixture type in section 3DView must be "color changer" ("par_can" is for old parcan style without RGB)
- the channel name must be "dimmer" instead of "Dimmer"
- there must be no levels in channel "dimmer"
Here is your file with the required changes.
P64LED.txt.zip
(406 Bytes) Downloaded 952 times
Johnny
Re: Dimmer Channel not working in 3d [fixed]
Post by Johnny »
Thank you very much for the speedy response and it works perfect now.
