Changing DMX channels
CH_NL
Post by CH_NL »
For a performance in a theatre I had send a lighting plan (inc. fixture positions, colors and DMX channels) to the technical crew. The show was entirely pre-programmed in Sweetlight (which worked like a charm bt the way) When arriving at the venue, I found out that they had chosen to ignore part of the plan. This brought me in a tight spot in which I had to re-address fixtures to different DMX channels in order to get them working. I had no time to check the forum, but I soon came to the conclusion I was going around this the wrong way.
* What is the best way to change DMX channels for fixtures in a pre-programmed show?
* Will this update all the scenes accordingly?
* In case of a multi-channel fixture (e.g. moving head), will I have to change each channel for that fixture one by one? Or if I change the first channel, will this change the subsequent channels automatically as well?
thx
CH
Re: Changing DMX channels
right click in ControlBoard > menu "dmx patch" > tab "dmx output"
The scene are not changed (no need).
In the software, you have to change each channel.
You can also edit the file "dmx_outputs_patch.ini" in your lightshow, and enter the patch manually.
Return to “Setup”
