the 'room' view is too bright, even on its darkest setting
Lucas_Story
Post by Lucas_Story »
I'm new here so forgive me if i'm posting this in the wrong section but i think the current brightness settings in 3D view aren't very good, the lowest brightness is still quite bright. I would personally love to see better brightness settings in a future update.
Re: Dark 3D
Noted.
dkumpula
Re: Dark 3D
Post by dkumpula »
Hi Support,
I agree with the request and would add that while you are adjusting this to please ensure that the brightness of the devices scale linearly with dim. Frequently I find my devices that look appropriate when the device is at full brightness, but they can't be seen in 3D at all when set to 1/3 of full power.
Thanks as always!
-David
Clive
Re: Dark 3D
Post by Clive »
Hi Support,
I have been visualising in 3DView, great application, but I too agree that the 'room' view is too bright even on its darkest setting. Is there any news on this since the start of this thread; or perhaps a workaround - a registry setting that can be tweaked or something?
Many thanks.
Re: Dark 3D
Noted in ToDo list.
zkflow
Re: the 'room' view is too bright, even on its darkest setting
Post by zkflow »
For me the solution was change the values for color in all the fixture to get the darkest setting posible... but that's very annoying...
Lighter007
Post by Lighter007 »
zkflow wrote:For me the solution was change the values for color in all the fixture to get the darkest setting posible... but that's very annoying...
I did the same, but, as zkflow just said, it is annoying. :|
Greetings from Germany! :)
