Macro Lag
Later than version 6.31
Macro Lag
Post by Pink LD »
Support:
So I have every current beta file loaded on my:
Gateway ZX4250
Win 7 Home Premium 64 bit
AMD E-300
Radon HD Graphics 1.30 GHz
And a second monitor through a USB adapter
The first thing I've observed is that Macros have a lag of a second or so from being clicked to engaging. But scene buttons on their own are instantaneous as I am used to.
Do you think this is my system? Or the fact that many of my macro buttons are activating several dozen or more scene buttons at a time and some buttons have up to 30 presets?
However all worked fine on the beta releases early this month. This problem presented once I had installed the current Beta releases available.
Re: Macro Lag
Post by Pink LD »
Update:
Macros with few scene buttons and just fade up fade down functions aren't lagging.
Still the way I use Macros and Preset Scene buttons for control over individual fixtures behaviours, I can project a time when I'll be activating 50-100 scene buttons that have preset information, fade in/out information, pause and/or no loop information. And potentially button speed info, because that was a feature I asked about earlier today.
eedetail
Re: Macro Lag
Post by eedetail »
I noticed a similar lag, but it seems to be when using the 3d visualizer while checking programs.
I am not using many macros, but have lots of buttons and lots of images on them.
Similar setup, and all latest beta updates too.
Re: Macro Lag
Post by Pink LD »
I found it to happen with or without 3D imager up.
Re: Macro Lag
Please send us your lightshow.
We will check that.
Re: Macro Lag
Post by Pink LD »
Sent it.
Re: Macro Lag
Post by Pink LD »
UPDATE:
I now have all the latest Beta files from the 21.12.12 and the lag has gone.
by eedetail » 18 December 2012, 13:03
I wonder what eedetail has experienced. But for me I consider this fixed. Thanks.
Re: Macro Lag
Should be fixed in Live.zip from folder "fix_files".
If still some problems, please make a new post here: viewforum.php?f=29
Return to “beta files [closed]”
