[6.20] 3D Cloned LedRain64 & Intimidator1.2 Bug [fixed]
DoubleDee
Post by DoubleDee »
First things first- You guys are doing an awesome job of fixing all the issues we are all throwing at you. Thanks for all your hard work.
Now my problems:
1- Cloned LedRain64 doesn't respond in 3D view. Or should I say, only the RED fader responds.
2-I have 2 Intimidator 1.2 scanners, one addressed at 3 & the other addressed at 8. The shutter on the second fixture will not open on it's own. It will open if the first scanner's shutter is open OR if a gobo is selected on the second fixture.
3-Not a big problem but something you might need to be aware of, I noticed that when in Fixture Settings of the 3D window the color faders only go up to 254 not 255.
Thanks again.
dd
Re: [6.20] 3D Cloned LedRain64 & Intimidator1.2 Bug [fixed]
Thank you for your comments, and you clear issues report.
"1" & "2" are fixed in the "fix_for_Windows" zip file (see FAQ section)
"3" is noted in the todo list
