USB connection fails randomly
buensabor
Post by buensabor »
Do good afternoon, I am writing because I have problems of USB connection, the connection on the Remote box not adjusted properly resulting in a connection failure, I could tell where should I contact? Greetings and thanks
Re: USB connection failed
Please contact your retailer for maintenance support.
buensabor
Post by buensabor »
Follow the problem after replacing cable connection, the connection fails randomly, show me the email of maintenance support?
It looks like the usb connector on pcb must be changed.
Two solutions:
- in order to save time, you change it in your side. You can buy the required part here: http://radiospares-fr.rs-online.com/web ... b/6741328/
- you return the interface to your retailer, for maintenance service
buensabor
Re: USB connection fails randomly
Post by buensabor »
Connector replaced, continuous random error in failing connection.
Where housing costs for repair?
Return to “Remote”
