will not work on android 2.3.6
troubadour
Post by troubadour »
Hello there,
until about 2 weeks ago, live mobile worked fine on my samsung ace with android 2.3.6.
I updated live mobile and after this update i cannot talk to live anymore.
I get i socket error.
Reinstalling does not fix the problem, because this version of live mobile is the problem, and that is the version you can download and install.
There are many more that have this problem, look on the download site !!
There are more people using the old software or an ipad, and then everything works fine.
So plesase fix this, or make it an option to install the old version.
With kind regards, Jos ter Horst.
Re: will not work on android 2.3.6
Yes, there is a problem with the IOS app.
The Android app is a different app.
troubadour
Can you please put the old version back again to download, because this one worked fine, and i bought, installed the software to be able to use it, and now i cannot use as i planned.
troubadour
Hello there, reading in all the groups about version 2.0, this one doesn,t work, so stop trying, put 1.1 ready to download, so that we can all benefit from the good things, instead of getting a headache from the new version.
And put version 2.0 back up when it is working as it should.
With kind regards, Jos.
Both are available here: viewtopic.php?f=3&t=114
troubadour
Hmmmmm and where can i find live_mobile version 1.1 ?? because searching everything in the link you put on as an answer, there is no version 1.1 for android or the version for ios
We only have problems with live mobile and want that back the way it was, WORKING.
It it ain't broke, don't fix it !!
There is only the apps for Android (1.1 and 2.0).
Apple® does not allow to self install apps.
troubadour
But where can i find version 1.1 for android ??
I cannot find it anywhere.
And why not go back to the working (old) version ?
The Android app V1.1 is available here viewtopic.php?f=3&t=114, in "The smartphone app" > "direct download"
troubadour
and when is the new version coming ??
We still have problems with version 2.0, it doesn't work !!!
And sometimes the android and the apple versions are updated, and then it doesn's work anymore, so fix this, make a version 3.0 or remove/take back the crappy version 2.0 !!
Jos.
Return to “Android”
