Moving Heads - Reverse pan/tilt [fixed]
djkre8r
Post by djkre8r »
I have 2 Chauvet Legend moving heads. On Legend 1 I have REV Pan and Tilt selected in the fixture setup menu. Legend 2 remains default. I do this so I can point both lights left, right, front, etc at the same time. In my 3D View however, the beams are reversed. Point fixtures to the left and they criss cross on the 3D View. I remember long time ago there was a setting somewhere that fixed this for the viewer. Where is this located now or how do I set this up? Thank you in advance for your help.
djkre8r
Re: Moving Heads - Reverse view
Post by djkre8r »
This may be a reverse setting in my light fixture itself. Should know after this weekend.
It is possible to reverse pan/tilt in Setup tab "dmx addressing".
It is possible to reverse 3D pan/tilt in Setup section "3DView".
djkre8r
Post by djkre8r »
After playing with the pan and tilt settings on the lights and in the setup... I got it. It has been so long since I have used ShowXpress. Glad to be back playing with it. Now maybe I should actually use it. Thank you.
