Moving Fixtures in Existing Scenes [fixed]
create lighting scenes
daneboy330
Post by daneboy330 »
I have to make some changes to our lighting setup, which will require me to re-address several fixtures. The problem is that we already have a bunch of scenes created. Obviously when I move the fixtures, the channel values don't move with them. Is there an easy way to transcribe the values from the old channels to the new other than writing down the values and resetting them?
Re: Moving Fixtures in Existing Scenes
Right click in ControlBoard > select "DMX patch" > Select tab "DMX output" and patch the channels to the dmx outputs.
Example: Channel "1" to Outputs "10+21+31"
daneboy330
Re: Moving Fixtures in Existing Scenes [fixed]
Unfortunately I can't do that because I am combining two universes and there are stage dimmers that will be using those channels. If I don't maintain a 1:1 patch, it will make things too confusing.
Return to “Editor”
