[MacOS] Audio Output Level Low in Timeline
qhome
Post by qhome »
When I play a timeline the audio file is output a low level. Itunes, VLC, quicktime all play the file at the appropriate level. I am using a modern mac laptop outputting the audio from the headphone output. I cant even get the level high enough with the gain control on my mixer. Is there a setting in showexpress for this or any fix?
Re: Audio Output Level Low in Timeline
You can adjust the sound level here:
- right click over the media file
- select "Properties"
- slider "Volume"
qhome
Post by qhome »
Thanks so much for the quick reply, however, the slider is at 100% and the output is still lower compared to quicktime, vlc, or itunes playback of the same file. Any suggestions?
After checking (with Macbook), we see a difference to.
Noted in TODO list.
qhome
Re: [MacOS] Audio Output Level Low in Timeline
Post by qhome »
Thanks for checking, I will adjust in my mixer for now. Thanks to you and your team, I really appreciate the showexpress product. I have reasonably mastered the showexpress software and am creating light shows superior to others that are using much more expensive hardware and software.
Thank you for for this comment.
Return to “TimeLine”
