[6.01] fader 2 drives dmx output 1, and so on [fixed]
fotogeci
Post by fotogeci »
Driver and software instaled well but when i whant to use fixtures then i cannot controll it because all channels are messed up. That only happens when i use cable dmx usb controller. With box512 is all ok. The cable dmx works only with showexpress 5 software.
Re: Sweetlight software 6 not working with cable dmx controller
There is a chance that you have this problem: viewtopic.php?f=11&t=71&start=10&sid=3f ... 5881fc9129. In that case, please download and install the fix file.
fotogeci
Post by fotogeci »
I have installed the fix and now it works just fine. Thanks for support.
Return to “Cable”
