Par Cans Flicker, didn't before last update (I think)
RoyalJenner
Post by RoyalJenner »
Hi
My par cans RGB 7 channel LED lamps. To my knowledge, I changed nothing.
- I didn't change the profiles
- I didn't change the scenes.
- everything used to work as it's supposed to
I believe that the 6.3 update may be the culprit? Now when I use 3D I get flickering of the lights and not usual on or off of the beams. VERY odd
My scenes are just on/off for 1 second, then I control the speed by bpm.
Note: the actual LED's work just fine.
Re: Par Cans Flicker, didn't before last update (I think)
You can send us your lightshow ; we will check that.
RoyalJenner
Please refresh my memory on what file it is I have to upload. :oops:
right click in ControlBoard and select "Export LightShow".
RoyalJenner
I think I did it rigth. zipped the whole folder for my current show build in progress.
Thank you
We do not understand.
We see 2 fixtures:
#1 - 3 channels: pan, tilt, dimmer
#2 - 4 channels: color_macro, red, green, blue
