3D fixture acting ODD in rotation
RoyalJenner
Post by RoyalJenner »
Hi
Trying to rotate a fixture... the x, y and z axis are highlighted in yellow fine. However, the fixture rotates around a different axis :shock: than the one that's highlighted when I move the slider.
This is the first time I've encountered this. It's with a strobe. What file of the show folder should I be attaching?
thanks!
Re: 3D fixture acting ODD in rotation
Noted.
This is not a big issue.
You can rotate the fixtures, in all positions anyway.
You probably set to the max one or more of the 3 values x, y, z then the result seems to act on another axis ...
RoyalJenner
Hi Support,
I don't think I communicated clearly. The x, y and z axis all show up (green markers with circles) when I click them. Problem is that the fixture doesn't react to one of them about that axis. It actually acts as if it's rotating about one of the others.
My values are all 0 or 90 degrees.
ODD :?:
