Minor Error in Setup - Insert Level
dkumpula
Post by dkumpula »
Hi folks,
I just noticed a minor error I noticed in the editor. When a level is changed to start at something higher than zero (e.g. 0 changed to 1), the "insert level" button is not immediately enabled. If you save the device and go back into it, it does display the "insert level" properly. (Note: Changing the top value of a level from 255 to something lower does correctly enable the "add level" button.)
This is a very minor issue, to be sure.
-David
Re: Minor Error in Setup - Insert Level
Thank you for the info.
Noted.
Return to “Setup”
