Showtec Sunstrip invisible in 3D
Dennis
Post by Dennis »
Hey everybody,
I've installed 4 Sunstrips from Showtec in Sweetlight, but I can't visualize them in 3D, which is necessary to program my lightshows. Can anybody help me out with this? I also would like to know if any preset programs exist for those same Sunstrips.
Thanx all for your help,
...Den...
marco
Re: Showtec Sunstrip invisible in 3D
Post by marco »
Hi dennis
If you want to program sunstrips u need to program them as a simple par
For ex. If you sunstrip has 10 channels you program 10 pars. Then in 3d u can see the output
For live use it doen't matter of u program the sunstrip or a par
The program only sents out the value of the adres
Hope this helps
There are no presets
Gr marco
Dennis
Post by Dennis »
Thanx Marco,
I'll do like this to be able to see my programming at home and being able to execute those programs on stage...
Thanx for your help, too bad that the sunstrip doesn't exists in 3D, but this will do...
Gogogogo Sweetlight...
...Den...
It is possible to change the shape of the fixture (menu "Fixtures setting" > section "Fixture shape"), but the beam stays circular.
