I do not see my "diff. colors" par can in Generator [fixed]
create lighting scenes
Pascal
Post by Pascal »
if i load differend collers of par can in generator they are not showing up so i can use them in the generator, can any one tel me how i can fix this so i can make loops
Re: Par can
In Generator, it is possible to adjust only values of levels. The popup menu which shows levels icons/names is available only in Editor.
Pascal
Re: Levels icons/names in Generator
Post by Pascal »
i have add a picture of what i get to see, i have selecte 8 parcans thay have only a dimmer function from 0 to 255. but when i select the group they dont show up in the genarator as you can see in the picture
Generator shows only commun channels.
If you rename the channels "par green", "par red", "par blue" by "par", you will see the channel in Generator.
Return to “Editor”
