pan / tilt reverse
Shakes
pan / tilt reverse
Post by Shakes »
I was wondering at what stage in the signal chain the reverse function is implemented.
I don't use the function and address my heads seperately (They are definitely NOT set to reverse) Problem I have is that in 3d view they all appear to pan in reverse to the actual fixture. The heads themselves are not set to reverse in their panel setup menus.
I've tried reorienting the fixture in 3d settings but it makes no difference, the view is always opposite to the fixture. :roll:
Re: pan / tilt reverse
Shakes
Post by Shakes »
Thanks.
Return to “Setup”
