Editor - resize option?
create lighting scenes
Zoran
Post by Zoran »
I use for many years sweetligh cable controller and it is great staff (I got 4 of them, also tried some others but I really like your software/hardware)
V6 got many great improvements... my problem is that I still use V5 and reason is simple: how to use F4 - resize option in V6 ?
I'm mobile DJ and I rent light every week and use light on different places so each time I have to make corrections in moving scanners/heads, V5 got the best options I saw but in V6 I can't find any similar options. If is there no that option will you in future have something like that i V6.
Re: Editor - resize option?
Editor is now only for "editing".
XY movements are now made in Generator, which is much more powerful.
In generator, you can save/load/edit projects, and you can load/save/resize movement shapes (curves).
Then you have to generate the new modified scene.
Zoran
Post by Zoran »
Thank you for quick answer, probably there's no way to send already made movements from editor to generator...
Unfortunately not.
But it should be easy to redo similar (or more nice) movements from scratch with Generator. We encourage you to try it.
Return to “Editor”
