Live Button does not play simple chase scene
qhome
Post by qhome »
I programmed a scene where I simply created a chase with 4 Chauvet ColorStrips. In Editor the program turned the first fixture blue for .5 second. The second step turned that fixture off and turned the second fixture blue for .5 sec. The Third step turned the second fixture off and turned the third fixture blue for .5 sec. The last step turned the third fixture off and turned the 4th fixture blue for .5 sec. The chase played fine in editor, however, when the scene is assigned a button in live the scene does not play.
Re: Live Button does not play simple chase scene
Can you please check if this is not same problem than 'zChris' had here ?
viewtopic.php?f=29&t=1130
Shakes
Post by Shakes »
Check that you've got dmx or 3d enabled on the live page. Close the editor page or turn off the outputs as that takes priority over live.
qhome
Post by qhome »
No, I don't have a basic problem with making buttons in Live work. It appears that "zChris" couldn't get any type of scene to work in Live. I have programmed several buttons in Live using flash, macro, etc and they work just fine, however, those scenes did not involve multiple fixtures programmed in a sequential chase. My problem is limited to a scene as I described using multiple fixtures in a single program thread.
qhome
Post by qhome »
Are you still looking into this issue? Any thoughts on what could prevent a live button from executing?
You can send your lightshow, and tell exactly how to proceed to see the problem.
We will check it.
Return to “Buttons”
