Generator problem - Complex Fixture
create lighting scenes
paulgormley
Post by paulgormley »
I am putting together a lighting controller for a new system a friend of mine just built. I know I am really going the hard way at this, but I have emulated a Blizzard StormChaser (Which my friend has 8 of in an 8 armed star pattern). The Stormchaser can be found here: http://www.blizzardlighting.com/index.php/stormchaser and its user's manual can be found here: http://www.blizzardlighting.com/index.php/stormchaser.
What I have done is set up a 31 Channel fixture and SO I can see it in 3D, I pushed 28 led panels together. 7 sets of Red, Green, Blue and "White" blocks. Everything seemed to be working fine until I tried to use Generator (the real reason I wanted to use this software to control these litle babies.
Anyway, When I define a group with only 1 color in it, the generator channel is populated with Blue, Red, Green or White. When I try them in any combination, the channels are blank. Any ideas as to what I might be doing incorrectly? I have a file I can let people download from Google Drive, just ask for the address and I'll supply it to you.
Thanks for any advice you can give me. I have set up an American DJ Nucleus before and it works really well, so I have a little experience in fudging the fixtures I want to use.
Paul Gormley
Re: Generator problem - Complex Fixture
You can send us your lightshow.
We will check it.
Return to “Editor”
