preset > left click does not change values [fixed]
TwoSound
Post by TwoSound »
When I add the 'preset button' function to a show in the live mode it only works correct when clicking and towing the preset to 1-2-3 for example. When I click on preset 1-2-3 the fader moves to this position but the software doesn't act like it. When i tow the fader button is does works. Can this problem be solved? I use this for light dimming settings. Thank you!
Re: Error preset button in live mode
We do not really understand the explained problem.
But, we just checked (Windows), and it works as expected.
TwoSound
Post by TwoSound »
When you select de button in the fader and tow it, it works as it should but when you press one or more stepps further then the button in the fader stand, then the button jumps to its new position but the fixture doesn't respond on this action. Only when i tow the button to the new position it responds. It's hard to explain in text but i hope you can understand it this way?
Understood.
This problem is fixed (only in beta version for now).
TwoSound
Re: preset > left click does not change values [fixed]
Post by TwoSound »
Perfect! I'm looking forward to the next update :-)
You can also try the beta version ...
Return to “Buttons”
